Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
hole in ceiling
2 REPLIES 2
nasanin.rashidian
750 Views, 2 Replies
hole in ceiling
I have a building model which contains 2 floors. There are also stairs in the building. Between the stairs there is a ceiling and I cannot draw a hole in there. So the stairs go “into” the ceiling. How can I solve this problem? on the picture you can see the front-view. and I need to remove only a part of the ceiling. I considered drawing a vertikal hole, but it does not allow me to do so. .
2 REPLIES 2
dear
I think you have modify the sketch lines/boudary for the ceiling. and just add another rectangle/boudary for opening required for stiar. you will get the result.
Irfan
A "Shaft Opening" element will cut not only the floors, but also any ceilings and roofs it intersects.
You can sketch the shaft opening to match your stair layout.
Joe
