Revit Structure
Revit Structure
Valued Contributor
17 Kudos
Post 1 of 4
Hidden corbels of precast column appear unwanted
410 Views, 3 Replies
02-07-2013 05:41 AM
Insert "M_Precast-Rectangular Column with Corbels" column into project.
Hide some of the corbels.
Join column with floor (or attach top and etc).
Corbels reappear without possibility to hide them again.
Any ideas?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
23 Kudos
Post 2 of 4
Re: Hidden corbels of precast column appear unwanted
02-11-2013 01:12 PM in reply to: Priitl220
This is known behavior that the development team is currently investigating; the visibility settings are lost when the column is joined to anything. Once the settings are lost they cannot be undone - a new column has to be placed. In the meantime, you may want to try to avoid actually joining it or try creating separate families for each representation.
I am sorry for the trouble that this causes to your workflow. Please let us know if there is anything we can do to help.
Katie Langan
Technical Support Specialist
Customer Service & Support
Valued Contributor
17 Kudos
Post 3 of 4
02-11-2013 10:24 PM in reply to: kathryn.langan
 I reported it two versions back (RST 2011) and still the answer is the same...
23 Kudos
Post 4 of 4
02-12-2013 04:39 AM in reply to: Priitl220
Yes, this issue is not new to 2013. Unfortunately it has proven to be complex to address and the development team hasn't been able to resolve it yet. I apologize as I realize this certainly isn't ideal but I do assure you they are working to address it. I am very sorry in the meantime for having to work around it.
Katie Langan
