Hi there.
I have revit structure 2010. I am setting up the drawing standards for this so that they match our current Autocad standards. We are using the Coarse style for all our drawings.
I am having some issued with the hatching that is shown with walls (see attached file). The problem is that aswel as showing the cut hatch, revit appears to be applying a hatch to walls that are hidden in the 'hidden lines-projection' catagory of the object styles. I need 'hidden lines-projection' to be a thicker lineweight than my hatching and so i get these wierd hatches coming out. Is there anyway I can tell revit to only hatch a wall in section?
Any help would be much apreciated
