Revit Structure
Valued Contributor
kevms
Message 1 of 4 (361 Views)
Hanger columns
361 Views, 3 Replies
01-05-2012 06:13 AM
Hello All
I have two high beams and and I need to put in two hanging columns. Can anyone tell me how to do that
Thanks in advance
Kevin
Kevin
Using Revit Structure 2012, 2013, 2014
I think I am getting the hang of this revit stuff
Product Support
Chris.Aquino
Message 2 of 4 (343 Views)
Re: Hanger columns
01-09-2012 10:21 AM in reply to: kevms
I would place your columns from the level above (the top of the column), then use the Top and Base Offsets to control the top and bottom of the columns.
I would appreciate it if you would let me know if this answers your question. If it does not, please reply with more information about what you are trying to do so that I can provide a better answer.
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
Valued Contributor
kevms
Message 3 of 4 (335 Views)
Re: Hanger columns
01-10-2012 05:24 AM in reply to: Chris.Aquino
I already figured it out a few days ago, instead of having the column based on height, I changed to depth and then added a base offset to where I need it to go.
Kevin
Kevin
Product Support
Chris.Aquino
Message 4 of 4 (331 Views)
Re: Hanger columns
01-10-2012 09:33 AM in reply to: kevms
Thank you for let me (and the rest of the community) what fixed the issue.
Chris Aquino
The Revit Clinic
@Revitclinic
