Hello All
I have two high beams and and I need to put in two hanging columns. Can anyone tell me how to do that
Thanks in advance
Kevin
Solved by kevms. Go to Solution.
I would place your columns from the level above (the top of the column), then use the Top and Base Offsets to control the top and bottom of the columns.
I would appreciate it if you would let me know if this answers your question. If it does not, please reply with more information about what you are trying to do so that I can provide a better answer.
I already figured it out a few days ago, instead of having the column based on height, I changed to depth and then added a base offset to where I need it to go.
Kevin
Thank you for let me (and the rest of the community) what fixed the issue.
