Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
foundation slab depression
1 REPLY 1
3339 Views, 1 Reply
When I put an opening -2'-0" from the top of a 30" foundation slab for a sump pump for an elevator pit. The opening punches all the way through. When I select the opening I can see the opening stops, but the there is still a hole all the way through. Why is this and how do I fix this?
in the image i have the opening selected and my mouse is just rolled over the 30" foundation slab so you can see the out line.
1 REPLY 1
Joe.Charpentier
Any opening family that intersects an element automatically cuts all the way through it.
To do what you want to do, you will need to use a face-based void family.
I have attached a very basic sample file in which you can control the size on a per-instance basis.  You can also do this with in-place voids  if you have more complex shapes to model.
Joe
