Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Foundation problem: Wall radius is too small
4 REPLIES 4
jan
904 Views, 4 Replies
I am creating a foundation under a wall with round corners like this:
When I try to add a foundation under the round corner I get this warning:
Question: How do I get the corners to display correctly?
I can not change the radius without getting some harsh comments from the architect 😉
Regards
Jan Grenov
Tags (1)
4 REPLIES 4
gregamhale
in reply to: jan
I would suggest creating an "in-place" wall for the corners.  Use the "Component" tool to create these.  Create the wall with the same material and then join the geometry with other foundation walls to clean it up.  Nobody will ever know the difference.
jan
in reply to: gregamhale
Thanks a lot for the suggestion, but never got it to work. Things just do not display correctly.
Can´t get the cut material to display correctly, the automatic joining of the foundations result in strange shapes and when I try to join the existing foundations with the in-place-wall, nothing happens.
However I almost got it by disallowing walls to join and create a new foundation type just for the corner.
That leaves one unwanted line only, and I can live with that for now.
Regards
Jan
awes
in reply to: jan
Add foundation walls only to the straight wallsfoundwall.jpg. Let them cross. Make a void or two and remove extra parts. Is there some reason for having a curved foundation surface?
jan
in reply to: awes
Yes I think that must be the best solution.
