Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Floor / modify sub elements - HELP
1 REPLY 1
JillMarsano5345
413 Views, 1 Reply
I am trying to make a sloped floor for a showering room. The contours of the floor aren't cast from all the corners of the "L" shaped floor, but Revit automatically triangulates from all points around the perimeter.
Attached is a picture. The highlighted parts are the four corners the floor should slope from and the drain at the center.
1 REPLY 1
awes
in reply to: JillMarsano5345
Select floor. Add split lines from drain to corners. Adjust level at inner corner using shape handle if you want a 100% sloped floor and same level at perimeter.
