I placed a floor construction down on my framing plan, it is made up of concrete and metal deck. The floor construction overhangs the beams around the perimeter of the building. Now when i go to section i want the metal deck to stop at the middle of the beam flange, but i want the concrete to continue for the overhang. Any suggestions on how I could do this?
Solved by 5kings. Go to Solution.
Use the cantilever Checkboxes. They appear while editing the floor boundary. Select one of the sketchlines. You can set your concrete and steel cantilever.
Regards, Jordi
