I placed a floor construction down on my framing plan, it is made up of concrete and metal deck. The floor construction overhangs the beams around the perimeter of the building. Now when i go to section i want the metal deck to stop at the middle of the beam flange, but i want the concrete to continue for the overhang. Any suggestions on how I could do this?
Use the cantilever Checkboxes. They appear while editing the floor boundary. Select one of the sketchlines. You can set your concrete and steel cantilever.
Regards, Jordi
