Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Floor Coarse Scale Fill Pattern
1 REPLY 1
1804 Views, 1 Reply
I tried to modify the floor slab TYPE property " Coarse Scale Fill Pattern" and "Coarse Scale Fill Color". However, Whatever I change these two properties to different pattern & different color, I could not see any slab fill pattern and fill color in plan view.
if anyone know the reason, please give me a guide.
Jason
1 REPLY 1
lanl
Dear Li71we,
Slabs/floors need to be cut in order to show the Coarse Scale Fill Pattern. So if you want to show the coarse scale fill pattern in floor plan view, you need to adjust the "Cut Plane" of your current plan view range, to make it cut through your slab/floor, then the coarse scale fill pattern and color will show up based on your setting.
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Lei Lan
