Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Finding out what's changed in a model
1 REPLY 1
stgauss
294 Views, 1 Reply
So you generate your structural model for a building. And you send it off to the architect and the client. The architect sits down and reviews the model, and decides he doesn't like your 600x600mm column in the lobby, and changes it to 400x400mm. "Put more steel in there or something".
Then he sends the model back to you "attached with corrections".
How do you find out what he changed? Is there any tool that you can use to compare the two models and see that there's a column missing, a changed dimension, changed materials, etc?
What's your particular solution for comparing different models, or ensuring dimensional compatibility between architectural and structural?
1 REPLY 1
ukdxb012
in reply to: stgauss
Are you looking for something like this? https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com:comparemode...
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
