Hi all
I'm having trouble displaying solid filled regions when my discipline is set to structural. if i change to co-ordaination or architectural the filled regions show fine, then when i switch back to structural they disappear. i can still select them but they appear transparent.
Anyone know any solution to this problem?
Solved by lzaras1. Go to Solution.
Do you have the latest service pack installed? Currently it's Update Release 2. This update seemed to fix the same issue for us.
