Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Fill pattern problem?
4 REPLIES 4
489 Views, 4 Replies
My Poblem is that the fill pattern does not appear at all in the plans or the sections even if I modify the pattern sapcingor the the orientation in the host layer. So is there another prameter control the fill pattern visibilty?
Tags (1)
4 REPLIES 4
lzaras1
could be a number of things.  And not knowing for sure what your exact intent is, I'd ask you to post a couple of screen shots to show where you're having issues.
One thing you could try is to check your Detail level of your view.  If you're set to Coarse, you will not see fill patterns.
Leanne Zaras, CDT, LEED AP
AutoCAD 2010 Certified Professional
Revit Architecture 2012 Certified Professional
in reply to: lzaras1
hi
i am not sure if the screenshots is helpful but whatever i do the wall fill pattern always looks like image no.2 even if the detail levelm is set to "fine"
note:the drawing units is in "meter", the scale is 1:100
Tags (1)
lzaras1
where is your cut plane for your plan?  You can find this in your View Range.
If the wall is taller than where your Cut Plane is, you should be able to see the separate wall layers and patterns.
the cutting plane is 1.5m height and the wall height is 2.49m
the fill pattern is visible only in the 3D sections....I dont know why?
