one of my collegue is getting this error : A Fatal Error Has Occured : Application will be terminated. You have the opportunity to save recovery files for all of your changed projects. Would you like to save the recovery file.
And the message is too frequent and he cant work properly any one knows the solution to this. See attached jscreenshot for the same.
Thanks.
Mohan
Ensure you have the service pack installed.
Open the file with the Audit box ticked.
Unload or remove any dwg files as a test to see if they are causing the issue
Disable Hardware acceleration (Big "R" > Options > Graphics > untick enable hardware acceleration - close and open any files that were open when this was done)
