Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
External Tools - Add-in Assembly Not Found
2 REPLIES 2
backbonestructures
1576 Views, 2 Replies
When I open Revit Structure 2013 I get the following message:
Anyone knows what it is about and how to solve it?
2 REPLIES 2
AJA14
in reply to: backbonestructures
I'm not sure what caused the problem but you can check by going to the following folder.
C:\ProgramData\Autodesk\Revit\Addins\2013 (If you're on windows 7).
You should check for the addins already installed.
If you want a certain addin not to load, either move it to another folder, or add (.whatever) i.e. .dontload, ...  at the end.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Joe.Charpentier
in reply to: AJA14
Once again, Ali's advice is correct.
It looks like this Add-in is part of Hilt's "Objects for Revit" plug-in.
It looks like they only have one add-in "for Revit 2012 or newer".  (It's not clear to me how this would actually work)
If you're not using this, you could try to uninstall it from add/remove programs.
If you don't want to uninstall it, follow Ali's advice.
Joe
