I am trying to export just my steel framework to an .IFC file however my model also contains concrete beams and columns so i cant seem to split these up in order to export just the steel.
any ideas?
J
Solved by Alaaeldin_Alsahli. Go to Solution.
First, You need to use a filter for (columns, foundation and framing) based on a structural material = Concrete
make them unvisible
Then make sure you check (Current view Only) when the ifc save as window pops up
Here is a video of the solution
https://screencast.autodesk.com/main/details/c5badc17-14c5-416f-a65b-d9430b30f7c6
