Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Export to CAD (Export layers set by material)
5 REPLIES 5
siuwaicheuk0414
4943 Views, 5 Replies
When exporting to AutoCAD from Revit, I would like my steel columns to be put on S-STL-COL and S-CON-COL for concrete columns.
Is it possible? And how to do it? Thank a lots 🙂
5 REPLIES 5
Yes, under Export>CAD Formats>DWG, in the dialog box, upper right corner, modify the Export Setup.
I know how to export to CAD. But i want to sperate steel and concrete colunm in different layer.
Ah sorry, your original post was unclear if you knew that. So by default since a column is a column Revit does not distinguish, but have you looked into the modifiers? I have not time to test, but poking about seems you might be able to do it that way.
arunag
in reply to: conormccartney3897
You are very much right about the Layer modifier,just add the Material modifier for Structural column & you will get the steel & Concrete column in different layer when exported. Layer also named by material.
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
s.gamperl
in reply to: arunag
I also want to set special Layers for Materials. When I follow your instructions I can set the Materials just for columns, but I also need to set the Layers for Walls, Generic Models, Stairs, Floors ect. But in this categories I can´t finde the opinion to add materials like for colums.
@arunag Can you please help me?
Tank you very much!
