When exporting to AutoCAD from Revit, I would like my steel columns to be put on S-STL-COL and S-CON-COL for concrete columns.
Is it possible? And how to do it? Thank a lots 🙂
Solved by arunag. Go to Solution.
Solved by conormccartney3897. Go to Solution.
I know how to export to CAD. But i want to sperate steel and concrete colunm in different layer.
Do you know is possible?!
You are very much right about the Layer modifier,just add the Material modifier for Structural column & you will get the steel & Concrete column in different layer when exported. Layer also named by material.
I also want to set special Layers for Materials. When I follow your instructions I can set the Materials just for columns, but I also need to set the Layers for Walls, Generic Models, Stairs, Floors ect. But in this categories I can´t finde the opinion to add materials like for colums.
@arunag Can you please help me?
Tank you very much!
