Revit Structure
Revit Structure
Active Contributor
sorgjee
Message 1 of 4 (510 Views)
Export load combination to robot
510 Views, 3 Replies
01-16-2013 05:20 AM
I'm attempting to implement loads, cases and combinations in revit for exporting a model to robot. I am able to get cases, loads and combinations names to export. The combinations do not have any cases or partial factor included in them though. How do I get revit to export these combinations correctly? (RST and RSA both version 2012.)
Revit definition:
Robot result:
This is enabled in v.2013 of the link.
Product Support
Artur.Kosakowski
Message 2 of 4 (491 Views)
Re: Export load combination to robot
01-18-2013 01:50 AM in reply to: sorgjee
This just should be done (see the attached picture). Could you send the Revit model so that I could check this?
Artur Kosakowski
Active Contributor
sorgjee
Message 3 of 4 (485 Views)
01-18-2013 02:21 AM in reply to: Artur.Kosakowski
Hi Artur,
I've tried to get it to move back and forth several times now, and it looks like it will only transfer if the whole model is export from Revit to Robot, not when doing a smaller selection of the structure.
Product Support
Artur.Kosakowski
Message 4 of 4 (479 Views)
01-18-2013 02:59 AM in reply to: sorgjee
Artur Kosakowski
