Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Export load combination to robot
3 REPLIES 3
sorgjee
989 Views, 3 Replies
I'm attempting to implement loads, cases and combinations in revit for exporting a model to robot. I am able to get cases, loads and combinations names to export. The combinations do not have any cases or partial factor included in them though. How do I get revit to export these combinations correctly? (RST and RSA both version 2012.)
Revit definition:
Robot result:
3 REPLIES 3
Artur.Kosakowski
in reply to: sorgjee
This just should be done (see the attached picture). Could you send the Revit model so that I could check this?
Artur Kosakowski
sorgjee
in reply to: Artur.Kosakowski
Hi Artur,
I've tried to get it to move back and forth several times now, and it looks like it will only transfer if the whole model is export from Revit to Robot, not when doing a smaller selection of the structure.
Artur.Kosakowski
This is enabled in v.2013 of the link.
Artur Kosakowski
