Is it possible to export or import guide grids between projects? I thought it was but I can't seem to find any way to do it.
Solved by Alaaeldin_Alsahli. Go to Solution.
This is a good question. After some tests my conclusion is that you can't. But the best workflow for now is to save the last project as a Template then you will be able to find them in there.
We could consider your question as a wishlist. I encourage you to send a wishlist to Autodesk Development team via this site (link HERE) for your case.
You can "import" the guide grid by opening both projects and going to Manage > Transfer Project Standards then checking the "Guide Grids" box
