Anybody help me how to export from Revit structure 2013 to Autocad structural detailing 2012
When I export Revit declare "The required autocad structural detailing is not installed, detected, or set as default" and I can't do anything more
Hi @Anonymous,
Can you check out the suggested solution here and see if it works out for you?
Unable to export Revit model to AutoCAD Structural Detailing Formwork
Let us know if you need any further assistance on this. Thanks,
Hi
The cross releases integration between both products is not supported.
Regards
