In 2010 you are able to modify "text position,show view name, view name position, etc. However, in 2011, the only option available is " Elevation Mark" box. Attached are the two property windows.
Anyone know where I can find the other parameters in 2011?
Solved by kathryn.langan. Go to Solution.
Elevation Tags were changed in 2011 to allow for custom tag creation. In 2010 you were limited to the modifications you could make, and there is much more customization available in 2011. You can now make those adjustments within the family itself. I would suggest taking a look at the following document for more information: Creating a Custom Elevation Tag.
Please let us know if this helps!
Thanks, this helps for the new tags.
We have old projects which have old tags and we converted those projects to 2011.
The thing i have to do with those now, is modify the family and create new types I suppse.
