Please can someone advise what the following erroro message is in Revit:
'Element 31071 became corrupt at some time before this session'
The project is workshared, and appears to be working fine on most workstations, apart from a couple where the above error message is returnded when trying to open a local copy.
We have appeared to resolve the issue by using the audit button when opening, but obviously still have concerns regarding the state of the project.
please can someone advise,
Alex
Have you been able to identify what the corrupt element is using the Select by ID tool? If so, have you tried manually removing it, if possible? We had such an error and ended up losing the entire Project file - it ended up being a corrupt Family definition that could not be removed by any means, and any attempt to do so resulted in a crash.
Try recreating the Central file, and if the error persists, open a Support Case with Autodesk Support. It is likely that they will have to repair the Project file or send it up the line to be addressed.
