Hi there,
I customized a simple arch. door family and using it to create openings in structural walls. I've a precision problem with door width. Doors which should be 1010mm in width are ending up 1009.99999948 mm. Can you check the attached model and help me finding out the culprit. Thanks
Solved by SerhanB. Go to Solution.
