Revit Structure
HFB
New Member
HFB
Message 1 of 4 (186 Views)
Display settings of walls
186 Views, 3 Replies
10-18-2012 03:34 AM
Hi, I have a project that I modelling steel walls that are 7, 12, 14 and 16 mm thick. I want to be able to display the walls in certain views with two solid lines with 50mm distance and a hidden line in between (center of wall). This is the way the client is used to drawing the walls on certain drawings and I dont want to change the walls all to 50 mm walls and just have the name of the wall type to diffirent the thicknesses. I basically want the 3D model to be correct but be able to use the corse, medium, fine detail level to control how the walls are displaed on my views like I can do with my beams and columns. Is this possible for walls?
You want your 3D model to be correct. In my opion the best way is to create a detail component and lock it to the wall.
Active Contributor
5kings
Message 2 of 4 (178 Views)
Re: Display settings of walls
10-18-2012 09:38 AM in reply to: HFB
Maybe you can enable the analytical line in the wall. this is the core lie of the wall. Not sure if you can change the linetype to hidden tho.
Regards, Jordi
HFB
New Member
HFB
Message 3 of 4 (169 Views)
10-18-2012 12:17 PM in reply to: HFB
One idea is to use a beam family that is only visible in the plan view and lock that to the walls. That way I can control the thickness in the plan view without changing the wall thickness. And my 3D model will be correct. But it would be nice if I could controll this for the walls.
Active Contributor
5kings
Message 4 of 4 (155 Views)
10-19-2012 08:04 AM in reply to: HFB
