A standard detail view is like a plan view, it has a Cut plane and a View Depth.
Go into the view properties and change these to have the same value. I believe this will give you what you are looking for.
You can also make a detail view that behaves like a section, by using the section tool. Make sure you choose the correct type in the type selector when you create the section.
Joe
