Revit Structure
Revit Structure
Member
0 Kudos
Post 1 of 3
Cutting Similar sections on multiple locations
539 Views, 2 Replies
10-08-2012 03:47 PM
New on Revit so hope my question is understandable.
What is the best procedures to callout a section in multiple locations without creating multiple views?
And/or using the same detail reference on different locations of the building?
I have seen construction documents from others, where it appears this is achievable.  But I have not figured out a way to do this.  Hope some of you can help!
EJ
Use referenced details.
See attached image
Regards, Jordi
Active Contributor
6 Kudos
Post 2 of 3
Re: Cutting Similar sections on multiple locations
10-09-2012 01:48 AM in reply to: RCSE_EJ
See attached image
Regards, Jordi
Member
0 Kudos
Post 3 of 3
11-09-2012 10:30 AM in reply to: 5kings
Thanks Jordi. Thats exactly what i did. I sorta figured it out right after i had posted the question. Thanks.
