Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Cutting Similar sections on multiple locations
2 REPLIES 2
3007 Views, 2 Replies
New on Revit so hope my question is understandable.
What is the best procedures to callout a section in multiple locations without creating multiple views?
And/or using the same detail reference on different locations of the building?
I have seen construction documents from others, where it appears this is achievable.  But I have not figured out a way to do this.  Hope some of you can help!
EJ
2 REPLIES 2
Use referenced details.
See attached image
Regards, Jordi
Thanks Jordi. Thats exactly what i did. I sorta figured it out right after i had posted the question. Thanks.
