Would like to create a sketch type linestyle ?
Solved by alan.quinn. Go to Solution.
By sketch I'm assuming you mean a line that looks link it was drawn by hand. This is not possible in Revit, but go here for information on Line Styles"
However, once you have elements and geometry in your model you can use the Line Work Tool to change the appearance of lines. Go here for information on this:
Hope this helps and thanks for posting.
