I was wondering if it is possible to create a Family Parameter that reset itself when the family is copied (like the Mark field that gets blank when). I will use it mainly for structural framings (beams) and ideally walls.
I want to besure that the Engineers will insert a text in it and it has to be empty to be spotted.
Giovanni
Hello, and welcome to the Discussion Groups!
Not exactly. You can set an Instance Parameter to be a default value in the Family, and that will be the default value for new elements of that Type in the Project. If this Instance Parameter is already defined in your Family in the Project, you cannot overwrite the default value, unfortunately.
Also, if one is placing an element, one can change an Instance Parameter's value under Properties prior to the element's placement. Doing so will establish the newly inputted value as the new default, which will shoot your ambitions down. This value is reset back to the proper default value upon activation of the Create Similar tool.
