Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Converting Revit Files to Step Files
4 REPLIES 4
McCauley
13179 Views, 4 Replies
I have a request from a fabricator to send them STEP files so that they can import my 3D model into thier software to aid them in the detailing process. How does one convert a revit file to a step file?
Thank you
4 REPLIES 4
DarrenP
in reply to: McCauley
revit doesn't export to step files only fbx, dxf, dwg, dgn, acis(sat) file formats
this is in revit 2013
DarrenP
nccaddie
in reply to: DarrenP
Suppose one still needs to geberate step files from Revit and an intermediate format is necessary.  What would be the best course of action?
Dave
jmacklin
Dave,
I am currently trying to figue out the best way to do this as well. Seems like exporting a Revit model via .sat format into Inventor is a possibility. Once in Inventor you can export as .stp. I have no feed back as to whether this will give the desired results as of yet.
Josh
flabbins
A good way to achieve this is to export from Revit an FBX file. Import the FBX into Rhino, then export the STP file out of Rhino.
