Revit Structure
Revit Structure
Active Contributor
kentanner1346
Message 1 of 3 (3,871 Views)
Convert ACIS to Polymesh objects
3871 Views, 2 Replies
10-03-2012 10:21 AM
Importing autocad piping into project and recieve the following error : 'ACIS objects could not be imported, use qutocad to convert to polymesh objects'   any help would be appreciated !
Product Support
Lance.Coffey
Message 2 of 3 (3,856 Views)
Re: Convert ACIS to Polymesh objects
10-05-2012 04:32 PM in reply to: kentanner1346
If you are using an AutoCAD MEP DWG file, have you tried going through the steps in the following blog posting:
Importing 3D geometry from AutoCAD MEP into Revit MEP
http://revitclinic.typepad.com/my_weblog/2011/04/importing-3d-geometry-from-autocad-mep-into-revit-m...
I also found the following help topic with information on the type of ACIS objects that Revit supports for import:
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0061-Start_a_61/0066-Using_In66/007...
Lance Coffey
Active Contributor
kentanner1346
Message 3 of 3 (3,823 Views)
10-15-2012 05:30 AM in reply to: Lance.Coffey
Files where exported into dwg format from CATIA. Don't and can't find alot out about this application, however found if I would explode and purge the files I could then turn them into blocks... worked fine for what i needed.. recorded a little macro and 57 files in about 2hrs...
