how can i create a concrete beam with different cross section , for example; a beam with 5 m long and first 3 m is T section and last 2 m with L section
is there a way to make without any error for analysis
If you want to create object for your model outside the Revit Default Family then you have to use "Create in Place" option. Please follow the path:-
Structure > Component > Model in place > select the object category ( Structural Framing) > give a unique name of the beam > Create > Extrusion/Blend/Revolve/Sweep (as per your beam shape is required). After creating the beam give the material as per your requirement.
This is very handy process to create a family as per your requirement. Hope this process would be helpful for you.
Thanks & regards,
Subhradeep Sen
Kolkata
India
