Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Conceptual Form Simulation - Revit Extensions
2 REPLIES 2
jitayu
361 Views, 2 Replies
While Trying the tool conceptual Form simulation in revit extensions, it gives me the error saying "Mesh elements are not detected in the selection", Now I tried to devided the plane of the mass to create the mesh around it. Even after dediving the surface, it is still giving me the error. Can anyone suggest me how do i make this tool conceptual form simulation work? Is there any other way of creating mesh elements before applying this tool?
2 REPLIES 2
Pawel_Kociolek
in reply to: jitayu
After creating a form you need to use an option "Divide surface" for this form and then apply meshing pattern in Properties dialog (preferably Rectangle).
Then mesh is applied and will be recognized.
There is also a similar tool called Structure Generator - it enables to generate structural system basing on conceptual form
jitayu
in reply to: Pawel_Kociolek
I used the meshing pattern and tried to do it again and it is still not working.
