Hi.
I have a CHS column extending through a floor slab. I would like to show a void offset from the column edge. Is there a way to add this to the column family so that I don't need to draw a void in the floor slab. I have quite a few columns to add and I don't want to add the column and then the void.
Thanks Andy
Solved by Rafal.Gaweda. Go to Solution.
Possible.
Create \ modify existing family by adding void.
Mark "Cut" with Voids When Loaded
Then load family to model and then use ordinary Cut selecting floor \ slab first then this element
