Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Column cut-back stick symbol
1 REPLY 1
kirbybeegles4894
871 Views, 1 Reply
Can anyone help out with this display issue?  I'm trying to get the stick symbols for a column to show cut-back when they die into a beam (see attached image).  Both the column and beam family are set to display by project.Document1.jpg
1 REPLY 1
I figured out the answer...partially.  If you set the top connection to anything other than "none" then the coarse-scale symbolic line uses the cut-back distance as defined in the structural settings.  But this only works for the top of the column...I need the cut-back to happen on both ends, and only when th column frames into a beam.  Otherwise the stick symbol shouldn't be cut-back.  This seems like a fairly standard drafting convention to me.  Any ideas?
