I have a question concerning the ''Column Base plate'' extension in Revit structure 2012. when i take a Tube section (HSS) and use the extension it gives me an error : ''the Column section is incorrect''. when i use a wide flange section (W) it works. why the error for the HSS family?
Unfortunately, this profile isn't supported yet by this extension.
You can choose the W section and apply the extension and modify after the section to HSS without runing the extension.
