Please guide this questions ,
I create central file and also multi user local files ,and moduled is completed all designers. client said one changes architect wise revised in
the project ,so revit user-1 change in the module and also as per architectureal wise changed revit structure user-2, all local files synchornized central file, but still client asking is old only , how to come back first modlue , because 50 sheet complete all discipline engineer for full module ,and changed in sheet around 10sheet ,and module 25% changed as per client changes
any option there ,or once again rework again
please guide immediately
and in future project in revit save document wise (sheet,module) ,document wise how to i instructions for my revit user team
Regards
A.DHANASEKAR
Tebodin Mukesh Consulting Enginners
India,Tamilnadu,chennai
Hi Dhanasekar,
1st of all please make sure that your all "Local Files" are properly updated and saved or not as per your changes. Then "Save to Central file". I think it will be worked. If not work after this process then go to "Central File". Make it "Local file". "Copy" your all changes from your all "Local Files" and "Paste" them into that file. Then make it "Central File" again. I think it would be worked.
Thanks & regards,
Subhradeep Sen
Kolkata
India
