Hello All
I have a concrete retaining wall on an odd angle. I need to create some blow up details of the expansion joint however when I cut a section, obviously the wall will be on the angle that is modelled. what i want to do is to rotate the plan detail so the that the wall for say is horizontal and I will detail and add the required notes. Is there a way to do this?
Thanks in advance
Solved by kevms. Go to Solution.
If you're talking about plan callouts, you should be able to rotate them so that their edges are parallel to your wall. Then the wall will show up as orthogonal (horizontal or vertical) in the callout view.
Hey, I kind of discovered that I could rotate the call out soon after I had posted my original question. I didn't realize it at the time. But yes i am referring the to the call out and now all is good until the next question.
