Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Can't install revit structure 2014
7 REPLIES 7
Message 1 of 8
eng_shady100
775 Views, 7 Replies
Hey,
When i try to install revit strucutre 2014 it asks for revit 2013 disc
Any help plz !! 😞
http://i.imgur.com/BGfctj5.jpg
Tags (3)
7 REPLIES 7
Message 2 of 8
TravisNave
in reply to: eng_shady100
Did you download all the parts of the 2014?  And from what source are you installing from?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 8
eng_shady100
I downloaded it from a torrent link 😞
And it worked in my friend's device !!
Message 4 of 8
Downloading from a torrent file is not recomended... for any software. You never know what might have been changed or included in that download.
That said, try the link Install 2015 Software in the right column, it will take you to a page with instructions and links for downloading the correct files.
Lars-Ake Johansson
Sr. SQA Engineer
Message 5 of 8
eng_shady100
Ok i downloaded it from the site and i downloaded it for 64 bit cuz my laptop is 64
But when i try to install it, This message appears 😕 😞
http://i.imgur.com/v8adBUs.jpg
Message 6 of 8
You will need to install Window 7 Service Pack 1, should be availible trough Windows Update.
Note that you might have to run WU several times before SP1 even shows up.
Lars-Ake Johansson
Sr. SQA Engineer
Message 7 of 8
stgauss
Yeah... well... don't do that. Torrents are nice, but often they're taken from disc images that someone had access to at the office or at a friend's house or who knows, and so you get those kinds of problems. Probably the torrent you downloaded was taken from an upgrade version, that needs the previous version to run.
Fortunately you can get a working Revit installer from the Autodesk website, if it's for learning purposes:
http://www.autodesk.com/education/free-software/revit
Download your installer from there, and try it.
Message 8 of 8
And if it doesn't show up on Windows Update, or if you need to download it at a remote location (for example if you're installing on your home PC but need to download at the office), you can get SP1 from the MS Website:
http://www.microsoft.com/es-es/download/details.aspx?id=5842
