hi
I want calculated Weight Structures In the revit structural in the project.
How do Weight per meter And Then Total weight Structure To get.
Solved by awes. Go to Solution.
Add calculated value "Weight" to your schedule; Volume / 1 m / 1 m /1 m * 7800 = Weight of structural part (density 7800 kg/m3).
Add calculated value "Weight per meter" to your schedule; Weight / Length * 1 m = Weight per meter (in kg/m).
hi
thanks for you.
Hi
Revit Structure How to calculate the volume for STEEl?
On what basis?
L*W*H=volume
hay plese tel me how can steel weight quantites calucate in beams and column steel
Hello
Unfortunately Revit calculates the the wrong weight.
