Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Beam to beam connections
1 REPLY 1
stahci
418 Views, 1 Reply
Are they possible to do? Since they do not match the Revit extensions " Beam to column" or "Column to base" connection. I am unable to create them. Is there another extension, or work around?
1 REPLY 1
in reply to: stahci
There is an SDS/2 software add-in that you can check out on a trial basis.  It's pretty robust and might be exactly what you are looking for.
