Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
beam system tags
9 REPLIES 9
Message 1 of 10
haydenwse
1253 Views, 9 Replies
beam system tags
Is there any way to list the number of beams in a beam system tag?  I am working on a project that has lots of different sized systems in it would be nice to have it list the quantity.
9 REPLIES 9
Message 2 of 10
engr_mondo
in reply to: haydenwse
Yes, you can abuse RST Schedule feature.
Mondo
Message 3 of 10
haydenwse
How do you do it?  I have gone into the family editor for the beam system tag an it doesn't have a parameter for number of beams, count or anything like that.  the number of members shows up in the beams system properties dialog box but I can't find similar info in the tag.
Message 4 of 10
yosso
Do you want to show the actual quantity in the Beam Tag?  For example, W10x12 (22), which would denote that you had 22 W10x12's in the project?
Message 5 of 10
haydenwse
Yes, that is exactly what I need.  Can it be done?
Message 6 of 10
yosso
I meandered about the web at lunch - and found a topic where they created a shared parameter and placed the shared parameter in a tag as part of label.
http://revitclinic.typepad.com/my_weblog/families/
and
http://www.wonderhowto.com/how-to-create-shared-parameters-revit-architecture-255295/
I need to get back to "work" no more exploring the wonderful, wacky world of Revit - but maybe you can cull some wisdom from the videos. Smiley Happy
Mike
Message 7 of 10
yosso
in reply to: yosso
Still not what you want, but I created a shared parameter and added the shared parameter to the beam system tag.  You have to manually enter the quantity in the properties, so it's not auto-magic. Smiley Indifferent
Anyway, my Revit "play-time/lunch-time" is over, back to the real world. Smiley Sad
Good luck.
Mike
Message 8 of 10
haydenwse
in reply to: yosso
i was able to do that as well but it is really frustrating to have a quantity listed in the perameters dialog box and not be able to list it in a tag.  As Charlie Brown would say, AAAAHHHHHH
Message 9 of 10
mwrhalliday
I am having the same issue my firm uses the following format to label joists on our drawings:
TYPE MARK QUANTITY @ SPACING = TOTAL EXTENT
We have to workout and enter the quantity manually which is not desirable. My next step is to look at the Revit API and see if I can do it that way. It's annoying that revit works out the amount bit doesn't make it directly available.
I will be sure to share my code if u can get it working.
Mike.
Message 10 of 10
haydenwse
in reply to: mwrhalliday
Thanks.
This is just as frustrating as Revit not being "able" to calculate the CG of an element.
Rail Community
