When using the beam system tags the arrow attaches to the near edge of the beam instead of to the center line. On steel joists this is not a problem but if you are tagging full width members like precast hollow core or double tees the end result is that it looks like the last beam in the system is not the same as the rest. I have attached a view of a double tee floor to show this.
Is there any way to make the system tag arrowhead attach to center line instead of edge?
I cannot recreate what you are seeing. Did someone alter the tag? If you test in a blank out of the box file with default structural elements and the default tag what happens? If it respond correct (link my image) check your template (assuming your structure file came from your template). If it came from somewhere else track that firm down.
I have attached my test file. Thank for posting.
i stated in my question that this was on a precast concrete project. I was able to recreate the condition by changing the steel beams to the out of the box precast double tees.
