In a brand new model I started I have a sloped roof diaphragm modeled. I set the work plane to be the underside of the diaphragm and proceed to model a beam framing system. For some reason the beam system comes in 8" - 12" below the work plane. To put it back to the underside of the diaphragm I have to modify the Z direction offset of all the individual framing members. Is there a setting or some default that may have gotten changed that I can to fix to ensure that my beam framing systems come in at the work plane that I have set? I set the work plane and model the beam framing system all in the 3-D view; I didn't switch views during the process so I don't think the set work plane got messed up. Any help is appreciated.
Solved by gguevarra. Go to Solution.
Issue resolved. We forgot to update the out of the box families when we installed Revit 2014 - since the parameters changed and all.
