Revit Structure
Valued Contributor
Opel5
Message 1 of 7 (460 Views)
beam labelling and automatic schedule key
460 Views, 6 Replies
01-22-2013 02:44 PM
Evening All,
I'm trying to deal with a pretty specific task but after many hours scouring google and youtube I'm pretty stumped. I'm new to Revit Structure. I've got an imported steel first floor 2D beam plan in my revit model which currently shows the beam types "203x203x46 UC etc". I need to do 3 things:
1) update the first floor plan, getting Revit to logically sort and update the beam labels from the above steel size into logical beam labels e.g.
B1 = 203x203x46 UC
B2 = 533x210x82 UB
etc.
2) generate (I'm hoping automatically) a logical reference table:
beam label  |  beam size   |
B1              <beam sizes>|
B2             |                      |
B2             |                      |
etc            |                      |
3) create a CAD DWG of this first floor plan incorporating the labelling logic and key table above.
If there is an app or add-in for revit that helps (I have the horrible feeling I'm going to have to do this the hard way but worth checking) please let me know.
Any help would be greatly appreciated! :smileyhappy:
Many Thanks,
Scott
Valued Contributor
Opel5
Message 2 of 7 (459 Views)
Re: beam labelling and automatic schedule key
01-22-2013 02:45 PM in reply to: Opel5
Oh I'm using Revit Structure 2012 by the way if that helps too :smileyhappy:
Valued Contributor
Opel5
Message 3 of 7 (441 Views)
01-23-2013 05:20 AM in reply to: Opel5
Hi There,
Well I've investigated creating a beam schedule but it doesn't seem to have any option to connect the schedule table of beams (as sketched above, B1, B2 etc) to the actual beam tags and there seems to be no post on this forum relating to it. Very suprising.
This must be a pretty sought after feature for drafting, does any exeprt on here know how to do the 3 step process I mentioned in the first post? Or is there an add-on that helps in this area?
Many Thanks,
Scott
Valued Mentor
AJA14
Message 4 of 7 (430 Views)
01-24-2013 12:34 AM in reply to: Opel5
Hi. I am not sure if I understand you completely but what you're trying to achieve should not be difficult. Usually, for tagging, if you can't find what you need you can modify an exisitng tag family and incorporate new parameters. If the parameter you need isn't there, then you can create shared parameters. These can also be used in a schedule to report your beam labels and so on. Let me know if I can be of further assistance.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Valued Contributor
Opel5
Message 5 of 7 (421 Views)
01-24-2013 05:11 AM in reply to: AJA14
Hi AJ,
Many thanks for the tips :smileyhappy: I'm guessing the main hurdle would be to get revit to perform step 1 in my first post. I can't find any option for doing it :smileysad:. I can add tag's manually B1, B2, etc for each beam but the objective is to get revit to logically and automatically tag B1 to all beams of a specific sizes, B2 to another steel size, and so on. If you can provide any advice on how to do this it would be greatly appreciated!
Scott
Valued Mentor
AJA14
Message 6 of 7 (417 Views)
01-24-2013 06:24 AM in reply to: Opel5
Hi, well, performing the first task isn't that hard. First of all, you need to use the Tag All Not Tagged and choose the structural framing and assign the correct tag to use. The main idea is that the tag family you choose is the one you need to apply to all these beams. Since the tag family may not exist already in revit you need to create one yourself either by starting from and existing tag or starting with a new revit family template. Let me know if I can be of any assistance.
Ali Al-Hammoud
Valued Contributor
Opel5
Message 7 of 7 (410 Views)
01-24-2013 09:34 AM in reply to: AJA14
Thanks AJ :smileyhappy: I'll give it a go tonight
