Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
beam gap again????????????????
1 REPLY 1
543 Views, 1 Reply
Here is a big pain is the a@# problem, which I see alot of post on but never fixes my problem. Please see attached pdf for visual. I have beams framing to beams. On one end the beam plan representation is correct, which shows a gap between both beams framing into the girder beam. Now for was is frustrating me.........the other end only shows one beam with a gap and the other beam touching the girder. Before you ask none of the steel is sloped and it is all at the same level, please Help
1 REPLY 1
mneelam
I got the same issue but for me the issue is only if I got the beams / rafter sloping.
