Revit Structure
Distinguished Contributor
jgood
Message 1 of 2 (226 Views)
beam gap again????????????????
226 Views, 1 Replies
09-24-2012 11:09 AM
Here is a big pain is the a@# problem, which I see alot of post on but never fixes my problem. Please see attached pdf for visual. I have beams framing to beams. On one end the beam plan representation is correct, which shows a gap between both beams framing into the girder beam. Now for was is frustrating me.........the other end only shows one beam with a gap and the other beam touching the girder. Before you ask none of the steel is sloped and it is all at the same level, please Help
Active Member
mneelam
Message 2 of 2 (191 Views)
Re: beam gap again????????????????
09-25-2012 07:47 PM in reply to: jgood
I got the same issue but for me the issue is only if I got the beams / rafter sloping.
